Mark250
- Joined
- Aug 30, 2015
- Messages
- 1,243
- Location
- victoria,Australia
- Occupation
- heavy equipment technician
Hi,guys I really could use some help please, I have a Allight MS 7.5K-9 lighting tower and I need an electrical schematic please. the lighting plant is 240V 40hz
Can I run 240V single phase and 415 three phase off this unit? if so do I need to change or configure the AVR
The alternator is set up for 240Vsingle phase at the moment.
Alternator details off the id plates
Brand- Leroy Somer
Rating Plate info
voltage 415V
Phase 3
KVA 20
KW 16
Amp 27.8
information plate
LSA 42.2s5 j 6/4
S/n 037562 052
Date 2011 .07
RPM 1500
hz 50
P/F .8
AVR R250 shunt
exit. values
full load 30.5 V/1.29 amps
no load 0.53 amps
Thanks for any help
Mark
Brand- Leroy Somer
Rating Plate info
voltage 415V
Phase 3
KVA 20
KW 16
Amp 27.8
information plate
LSA 42.2s5 j 6/4
S/n 037562 052
Date 2011 .07
RPM 1500
hz 50
P/F .8
AVR R250 shunt
exit. values
no load 0.53 amps
Thanks for any help
Mark
