alternator 303.5 bolt hole
TomWei
the tension bracket broke on the alternator. when i pulled alt the bolt hole was 1.5 normal size. the bottom bracket holes are 2-2.5x size hole should be.
backets are coming in from australia but can i shim the alt or do i need a new one?
alt is 85 brackets were 400. guess i could keep as backup
afw00807
007
Not sure what you mean by shims but a lot of alternators come from the factory with steel bushes pushed into the alloy from new.
They are slightly over sized with a split down the side to allow them to shrink slightly as they are pressed in.
If you had access to a machine shop they look like they still have enough material left to bore out and fit a bush.
TomWei
parts came in yesterday to cat but bracket is backordered. guy was busy and people behind me so i just grabbed the parts they had. I'll find out tomorrow if its delayed or not available.
can machine shop bore the hole for bushing? it looks like 10.9 grade.
JLarson
AZ
I don't see why a decent machine shop wouldn't be able to clean those holes up then turn you some bushings.
