the other day i bought a new alternator for my D5 96J series. took off the old 19amp, and replaced it with what the manual said was used for the upgraded light package... 25SI delco 50amp 24v.
well i put that in. it was positive pole, with a negative frame ground. i tied the frame ground into the same bolt as the starter frame grounds (it was clean/free of paint)
after i fired it up and was seeing if it was working two not so good of things happened.
1st. the volt gauge only read 12v on the machine rather than if it was getting a charge 14v. the alternator generates plenty of power when i had the volt meter on its poles by itself....
2nd. turned it off and then tried to restart it and nothing out of the starter.
did i fry something? i never smelled anything cooking. by theory hooking the two on the same frame bolt shouldnt make any difference.
the volt gauge on the machine still reads 12v when i try to start and get nothing or when i try the glow plugs (it should dip under 12v).
i'm not much of a wrench bender but this should have been something pretty cut and dried and now is getting out of hand....
thoughts?
thoughts?
