Aluminum or Brass/Copper Radiator
mbavers
homer alaska
1984 M1008 After much research I have narrowed my replacement radiator to 2 sources: Rock Auto 3 row all aluminum ($624 total w/ship&tax) or Summit Racing 3 row brass/copper ($727 total w/ship&tax). They seem identical to each other and to the original. The money difference is not significant. I lean toward the brass/copper simply to avoid the anti freeze issue (too much to consider). Which would you prefer?
Acoals
Wisconsin
What is the anti freeze issue? There is no benefit in trying to keep the green stuff in there.
mbavers
homer alaska
Yeah, but I can't get a good feel on OAT, HOAT, NOAT, 2EH, etc. Too many choices; not enough info on actual differences and effects. Also, not sure if newer ones will be harmful to the old engine (seals, gaskets). Why don't all modern car makers use same anti freeze?
Acoals
Wisconsin
Try this thread; Nige and others posted some good info.
After you read all that, just put Final Charge red elc in it and be done. The new coolants won't bother the old stuff, just make sure lol the green is flushed out.
Joe H
Utah
Put those rockauto part numbers into amazon and see what turns up.
Joe H
mbavers
homer alaska
Read most of it. Now both my brain and eyes are blurry. I long for the old days.
Joe H
Utah
The old days it went bad, the new stuff is amazing.
I changed out the hoses,belts/idlers/radiator on my 03 Suburban last year. The inside of it was like new, everything was spotless.
Joe H
mbavers
homer alaska
I just got an answer from Valvoline Global:"We recommend our Zerex Original Green coolant for your vehicle. The formulation is designed for diesels and protects all engine cooling system metals from corrosion including aluminum
MarshallPowerGen
Northwestern USA
You're over-reading into it. Get the brass/copper rad, throw in some red ELC or green with additive and move on with driving it.
mbavers
homer alaska
I already ordered the aluminum one from rock auto. Aluminum seems to stand up well in modern autos, and the lighter weight will hopefully be easier on my back than removing the old one was (although the old one had the additional weight of some remaining coolant, trans fluid, and engine oil). I'm still recovering!
mbavers
homer alaska
Joe H
I decided to replace the lower radiator hose while the radiator was out. Inside and out the old (original) hose looked perfect, since 1984, using the old green stuff.
cfherrman
Hays, Kansas
I would choose the non-made in China one. When you get your radiator look inside it and see the crap welds and construction
