I see. So in order to get the same force, if I am doing the math right, for a type 30 chamber x 90 psi that would be 2,700 lbs force which would be 14 psi vacuum on a 193 sq. inch chamber or 16 inches diameter. Or maybe a longer slack adjuster or different ramp rate on the cam head. Or just accept brakes that did not work as well.
Probably all of the above.
Did the brakes have a long application time getting vacuum back to the chambers? Was there a vacuum reservoir and relay valves? I could see a loss of force at high elevation where the air pressure was lower.
