Not on that particular mill but starting at the age of I think 19, I spent at least 10 years running similar mills. Cincinnati's and K&T's. Happy I got in on the last of the major manual machining.
The big knee mills and verci powers I ran ranged from 30 to 50 HP that is huge for mills.
The number or size of the machine is determined by the horizontal table travel.
Number 3 is about 30 some inches, Number 4 would be close to 4 foot etc.
They are nice and stable for heavy cuts, I have done boring on them, but if its full mechanical you will not be power tapping with it. You have a better chance tapping on a turret mill (that Bridgeport).
That machine is way newer than the newest I would have run, 1970's models. And a bit smaller to, but we did have small ones as well. There are some outfits that may have parts for some of them, as that can be a issue nowadays. These old mills are essentially a transmission with lots of gearing, this one you show may be different some what there, I don't now.
RC is very correct, those turret mills, Bridgeports or Jets as well as some others are the best for
extreme flexibility. Easier to move as well, they are not super heavy cut machines but are pretty accurate. The larger machine good for roughing, heavy cutting. But need the HP to do that. Depending on what you need to do having both that and a turret mill would be handy. The Cincinnati would be great to cut J type or vee weld preps, we did lots of that on special stainless steel parts back in the day.
Yup I have worn lots of hats in my various careers. As far as machining I have machined some not so safe materials in the beginning days.
