When I bought my TD20G it had a piling blade on it (no center pin used) and came with a tilt blade separately. Last year I turned a pin out of some 80mm excavator pin. Hole was kind of worn on the upper hole, c-frame and lower hole were pretty good. I machined a step in the pin to accommodate the wear. Installed the pin with no problems used it, manually angling the blade with no problems. Went to take it out today to swap back to the piling blade, won't come out.
I pushed up on the pin with a 30 ton jack, pushed down with the dozer hydraulics. Pushed down, even hammered down with the excavator on the blade, it's stuck. Thought about welding a ring on top to pull on but I don't know if it will be enough.
Hoping to salvage the pin as I don't have any stock or time to build another right now. Suggestions?
