Acoals
I keep fire sleeve and spiral wrap in stock. I prefer the slickness of the spiral wrap as well as its hardened protective qualities over the fire sleeve. Fire sleeve does its job to contain a spraying leak so I use it in certain applications, sometimes using both types of overlay together to ensure a longer lasting repair or preventing what I know is a bad contact situation.
That is what I do, generally sleeving on internal stuff, wrapping on external hoses such as out on the boom of the excavator.
I find that zip tying the ends of the fire sleeve real good helps keep the dirt out and cuts down on the bunching. Usually two or three zip ties, as tight as possible.
That's a brutal amount of dust; I have worked in pit conditions feeding a dry screen plant where I had to bang the air filters out twice a day, but the picture you have posted is about twice the dust of those conditions. You must spend an hour a day cleaning things out . . .
