LT-x7
I don't have a whole lot of experience with these but I've never seen one anything like this. How is it possible it wore off every other tooth?
It's an old 235c cat excavator.
I was just curious what caused it because I would assume if the sprocket was replaced the new one would wear the same way in a short amount of time unless the problem was corrected.
I suspect the chain was shortened because of wear - if you get a situation wear the # of chain links is divisible by sprocket teeth , the bushings hit every other tooth so same teeth always wear
I'm sure this is the answer here. There is never supposed to be both sprocket and chain with both even or both odd numbers.
The chain will Lengthen because of wear, not shorten. Either way it will have the same effect and cause the pins to no longer line up with the teeth resulting in the wear you see in the photo.
The number of links and the number of teeth will not make a difference in wear as long as the space between the pins is correct. I worked for a company that removed a link from one track of thier excavator to shorten it. Almost all of the operators swore up and down that having a shorter track on one side would make the machine turn when it walked. Afterwords the machine walked as straight as ever.
Hey Jerry, don't you hate when somebody else is typing the same thing at the same time and makes you look like a copycat?
Mitch
