AWD front axle restore.
TVA
USA
Does anyone knows the company that restores the AWD front axle housings after the “king pin” tapered bearing rollers chewed the hell out of the housing?
Asking for the customer.
In my case it’s ZF MS-2025, on the JD 310-SG.
The housings is not listed as a spare parts.
alrman
QLD Australia
Any machine shop worth it's salt, should be able to do something with it - whether cost & repair time is a problem with this.
I have patched a few of the Carraro axles with similar problems .... ;)
See Here
TVA
USA
See Here
Thanks. But I am not interested in trying out the machine shops. I need to know which one already did it successfully.
TVA
USA
If it was my machine and wasn’t involved in the day-to-day work, maybe I would try.
TVA
USA
Have you considered a new or used replacement ?
New is more expensive than machine it self.
Can’t find used ones, but even if I will find it - it will probably have similar damage.
TVA
USA
Can anyone help me with part numbers for those housings? My parts source do not list them ( not JD not ZF).
Here’s a name plate.
TVA
USA
Sorry in that case. It was close to the top on a Google search.
I’ve e tried them with some pump drives - and they kinda played a “little stupid”, didn’t want say “no”, but didn’t help either. Ended up being “wee will call or email you back” deal - which never happened.
Tinkerer
No Problem TVA !
I just looked up the 310SG axle in the John Deere parts book. Copied the part number, and did an internet search.
That aftermarket one is the first one I saw.
If the tractor has the original axle under it, the JD part number should be correct for the one you are trying to repair.
Out of curiosity, maybe call a JD dealer and get a price from them. They sometimes sell aftermarket parts themselves. Depends on the dealer.
I would rather go with a new housing rather than repairing the old one.
