Ok guys I've read over the replies and now I have quesitons, is this basically a ford, chevy, dodge debate as to what one is the best, can we summarize the different catagories grease falls into and who makes what and who just labels the tubes, I'm thinkng that the one who said maybe all red tacky grease is same and only have different pachage on the outside more like the case but I don't know. Are we comparing chevy to chevy and the only difference is the paint color on the outside,
I agree with norite and asking about an independant tester done any testing on the different products. I understand the moly thing and have used moly and yes I like it and I'd also have to agree with the synthetics are only higher priced I've used lithium grease and several others as well, I'd agree that some grease does some jobs better but does anyone have a cheat sheet so to speak as to what does what job. My oil/grease supplier told me years ago that the only basic difference between grease was the basestocks use to make it and the addatives put into it, so red grease was the same as any other red grease except for maybe an addative here or there, is this true? I'm not lookng for a sales pitch but more of an information pitch on grease. Please keep the replies coming and thanks for the interesting reading so far a lot of these names I've never heard of before.
If you read back i explained why my recommendation is ideal for this kind of use.
I'll cover it quickly again....
1st...anything that
"slides" like 5th wheels,,backhoe/excavator ,payloader pins/bushings,,drive shaft splines,,or even tie rod ends anything with a high load application/requirements etc,,etc,,etc..
you want a Moly fortifyed grease..you ask why?? well because Moly(Molbdenum)is a very good,excellent
anti wear additive ok,and in these situations that's what is needed and wanted, obviously.
2nd..IF your looking for a good grease that will repel water hold up better against wash out and pound out and lets you grease LESS often your going to want a grease with a better base(thickener). Now most your common greases are going to be a lithium base(a thickener that will yes actually mix with water), yea it gets the job done but not ideal for this kind of use your going to want a aluminum or calcium complex base(thickener) this stuff will not mix with water has extra tackifiers in it to able it to "stay put" and not dry out wear off.
three greases that i have used are all covered under my above statement and are excellent grease with high timken ok load ratings.
http://www.amsoil.com/storefront/gpor2.aspx
http://www.schaefferoil.com/238_moly_grease.html
http://www.trclubricants.com/grease/moly880crownandchassisgrease/moly880crownandchassisgrease.html
