Well I'm a a$$.
And I don't know what I'm talking about.
And owe Big Iron a BIG apology. So here it is- "I"m sorry, and evidently don't know what I'm talking about".
I set up two cranes in the yard, and picked up my big spreader bar, with tensionmeters on each end- and put both screens in one cab. Stood the bar up and down so I could actually watch what was happening on each scale as I made a tandem lift. And I worked it all around in a couple different configurations, and it was a great learning experience.
With the bar and both cranes free swinging, weight stays pretty even until about 30 degrees, then it starts climbing on the upper crane and constantly climbs on the upper crane until it pulls it off of the tail crane.
The only time it raises the weight on the tail crane, is if the rigging jumps a little as it is rolling in a shackle, and "shock" loads the lower crane. I think you could push a little onto the lower crane also if someone was on a swing brake or off center a little, but I didn't really try that out with the bar.
But it doesn't load up the tail crane more if they are both freely suspended.
Interestingly enough, it is different if you remove the tail crane, and stand the bar just like you would stand a tank or tower with only one crane. Then you can actually loose pressure on the head crane as it "balances" itself - when it is breaking over center so to speak. Then the weight drops off of the head crane considerably as it stands at the end. Which I have trouble wrapping my head around how its actually different if the bottom is suspended from another crane vs. standing on the ground, but its different.
With the lmi idiot lights in the cranes, the raise in weight on the tail cranes that we see, must be rigging moving, causing shock loads to the tail crane. . Most of the things we stand up and lay down- don't have lugs on each end for raising and lowering. We are just steel chokering steel legs, or nylon roundups choked on the flat bottomed tanks we stand. So when the load approaches vertical, its not unusual to see chokers slide or rigging reseat itself.
That's the only explanation I have for the rise we see in the tail crane standing and laying down tanks. Its the momentary shock load as it goes vertical, and its rigging moving that blips the christmas tree lights. NOT the weight transfer of breaking over center.
If the raise or lower is smooth- the weight transfer stays even.
So all in all- Big Iron and the books are right, and I learned something. Too bad I just can't take someones word for it.
![Roll Eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
And again, I'm sorry for being a jerk about it.
![20200428_093006.jpg 20200428_093006.jpg](https://www.heavyequipmentforums.com/data/attachments/200/200507-0c76278bf3785c369dee2ef356892ad1.jpg)
