I recently picked up a used 7x16ft Big Tex bumper pull equipment trailer with what I was told has a 14K GVWR. I couldn't verify this because the manufacturer's data sticker had been worn off. I purchased this to be able to haul my MF 390 farm tractor (sorry, I'm not a pro heavy equipment operator). This trailer has a pintle hitch and surge brakes...which I did NOT find out about until picking it up. I have a few 'newbie' questions if anybody is willing to entertain them.
1. I've never owned or used a pintle hitch before. The lunette ring appears to be much larger than required for the pintle hook receiver mount that came with the trailer. The ring has a lot of play and therefore the trailer can slam/rattle forward and back in the hook as I accelerate and stop. See picture below. Is there a better setup to minimize or eliminate this slop to make towing smoother and reduce wear and tear? Is there any way possible to add weight distribution spring bars to a pintle style hitch?
2. Without any prior information on the trailer, how can I determine the GVWR? It does not have leaf springs, but does appear to have what I think is a torsion spring axle (see picture). However, when I jacked the trailer up it didn't seem to drop down at all, or at least I didn't notice it. I can't imagine having no suspension whatsoever, so maybe the weight of the trailer itself wasn't enough to displace it. The wheels are 8 lug and the hubs/drums have "8-219" and "10MT" cast into them.
3. I've never owned a surge hydraulic brake trailer. I was told before driving hours to go pick it up that it had 'electric brakes'. I was a very disappointed to find surge brakes. Any tips/tricks that I should know before hauling a load? How are they adjusted? There is a lever that is a mystery to me (see below). Should I look into converting it over to electric brakes?
Thanks!
BMFR
Thanks!
BMFR
