Bobcat e45
wrc
Topeka
can anyone tell me what e000731-20 code is on a bobcat e45? its been throwing that code regularly but appears to run/operate fine. Thanks
NepeanGC
Ottawa, Ontario
#dirtherder
Dont know what the code is specifically, but codes are listed in the operators manual for the machine. Normally stored under the seat, or behind it. Is it listed there?
TLO_Sparky
Tennessee
I just purchased a used 2016 T630 with a D24NAP(DL02-LEL03) engine and this same code is present. Purchased the SN specific Operator and SVC maunals from Bobcat and this Service code is not listed. Can't find anything in web search either...
Txhayseed
Texas
Accelerometer error code. Check the wiring connections on the throttle dial and the throttle knob itself. Harness itself may be an issue if it's shorted,rubbed ect. Same set up is used throughout the bobcat family and code is same on excavators and skids. Usually the throttle potentiometer It self is the culprit but inspection of wiring is always prudent.
