05sprcrw
I am fighting a small issue with the bobcat s300, and suspect its either my o ring on the pickup tube or the pickup tube itself. However before I go through the work of pulling the motor I thought I would check with others and see if anyone has had this issue.
The motor was overhauled within 50 hrs of this, its just now getting warm enough that the oil can get a bit thinner and I am using it longer stretches. It will run for about 1 1/2 - 2 hrs with pretty stable oil pressure of around 50-55 psi around 1800-2000 rpm when the oil is warm and will make 65-70 psi on a cold start up at idle before upping the speed. After that approx 2 hrs or a little faster if I am on mainly uneven terrain it will start to drop off slowly, until it starts to get around the 25-30 psi at approx 1800-2000 rpm before I get nervous and shut down. If I come back after a while of it sitting anywhere from a a couple of hours to over night it will start back up and have good pressure. Usually after I shut it down I am on to another project and don't need to get right back in it. So I don't have an idea if its temp related or something else.
Things I have done:
Changed oil 15w40
Changed oil filter
Changed the sender/sensor
Changed the oil pressure relief valve and spring
I picked up a mechanical gauge and will install that tonight to try and verify if my sensor and the mechanical gauge match to make sure a wire or something isn't the issue.
At this point I don't suspect the bearings have had any issues, only two things I can think are a little over filled on oil (upper limit on the dip stick but not over), or the pickup tube has a leak and air is getting in the oil. When I pull the dip stick there will be a few bubbles on it causing me to think air is getting in the oil. It doesn't come out covered in bubbles only about 3-8 bubbles (guessing but you get the idea).
Any help/suggestions would be appreciated.
Things I have done:
Changed oil 15w40
Changed oil filter
