Bobcat t190 parking brake issue
eblinn5
New york
Long story short I recently bought a t190 at auction and it has a few issues I've found so far with no luck figuring out solutions. First is the machine runs fine until you hit the parking brake amd immediately dies out or if you raise the lap bar it will immediately die, second issue is it is throwing code 75-41 which is right swash plate sensor out of range high however on the right side panel it says right swash plate sensor short to battery does this sound more like a wiring issue or a issue with the swash plate sensor.
crewchief888
NWI
harness would be the 1st place i'd be looking for damage.
cuz you really dont want to get to the swashplate sensor.. it's on the bottom of the hydrostat.
