Scotty Brown
Hey everyone, in my constant effort to fix the leaks on my old telehandler, I've run into an issue where the boom and fork tilt won't stop moving when I release the handle. It will stop if operating down, but not going up and if I tap the handle the other direction, it stops. This is a 1999 Terex SS1048. The main control valve was leaking so we took it apart and replaced the O-rings. This is a 3 part control valve with the top section controlling the boom in/out, middle controlling the tilt and the lower controlling the boom up/down. My thinking is that I have something, like an old O-ring piece, stuck in a port between the middle and bottom sections. But, before I start pulling it apart again, I wondered what others think. Is there a possibility that it's something else altogether. Everything worked great before taking it apart. Thanks!
