today I tackled the block heater and heater lines which is rather important where I live.
when I bought the loader they had a inline coolant heater that was installed by putting a Y fitting into the heater hose that ran to the 3/4" port tapping into the elbow flowing from the trans cooler into the block. the other hose of the heater tied into the 1" port on the elbow between the engine oil cooler and the trans cooler. I generally don't like these inline heaters, they work OK when installed good but usually they are not I've found. for some reason I still keep them as I remove them from stuff I buy lol.
My plan is to install a screw in 1500 Watt heater that I will put in that 3/4" port that flows into the block, this will let all the heat flow into the engine block and up to to the head where it needs to be. The heater hose will tie into the 1" port between the 2 oil coolers, I actually think this port is better and here is why:
Water flows from the pump into the engine oil cooler, then into half of the transmission cooler, loops back up through the other half and then into the block. water wants to take the easiest path and heater hoses and a heater core are not an easy path compared to the wide open block and head if you used the 3/4" port. using the 1 inch port you have that little bit of restriction the transmission cooler gives, which should flow a little more water through the heater. I would like to tie into the passage between the pump and engine oil cooler but there is no port and I don't think it would make enough difference to justify drilling and taping a hole. you might never notice a difference from the 1" and 3/4" ports but I have to use the 1" anyways.
I removed the stack of fittings from the 3/4 port, the had a 1/2 hose barb on that one. the 1 inch port had a 1 to 3/8 bushing, a 3/8 close nipple, a 90 and a 2 inch nipple as a hose barb. I reused the bushing, installed a street 90 elbow and apparently I have no 5/8 hose barbs left in stock so I machined the 2 inch nipple into a simple hose barb.
I then searched my parts area for the new 3/4" NPT block heater I knew I had for about 20 min, then I remembered I used it on another machine... so I have to order another heater I guess.
