Broke my new lowboy
OExcavating
missouri
first it was bad weld on ramps now slats on beaver tail broke,company say too much strain while loading.i know in time back of lowboy takes alot of abuse but mine is new and already having problems .anyone had one for awhile that hasn't had any issues with ramps or tail.
demo
pa
yea dont that really suck.. spend all that money for a new trailer so u dont have any issues and still broke.. i have a brand new fontaine 55 ton low boy with the best of everything and of all things to break it had to be my deck lock, bad weld. it hauled less than ten loads when it happened. i fixed it myself, didnt have the time for it to sit at the dealer when i could do it in a couple hours..
OExcavating
missouri
Neville Built , I am real happy with lowboy now but would not buy from local dealer in kansas city . neville did what it took to make things better
Tiny
NW Missouri
Which dealer ? I would like to direct folks away if they are messing customers around .
froggy
Pico Rivera, Ca
100% Lowbeder
froggylowbed
sorry i havnt replied,working24-7.the other day i saw a 16tire murray w/floating 3rd-axle it could qualify.
Dualie
Nor Cal
I wish Chas made smaller trailers, i been looking for something to haul my forklifts around behind the pickups and im right at the weight lmits without upgrading to more PITA truck sizes and a whole norther can of worms. I had a Murray 16 tire and it was the bees knees but that work left the area FAST. so it left too.
a dual tandem gooseneck built from T1 like is bigger brother would be the cats ass.
tonka
Longview WA
Equipment Operator
yeah that would be nice, like one of them dropbody trailers...with deck that sits on the ground when unloading
Newman
AZ
The only problem is most people don't understand that you get what you pay for. They would probably be more expensive due to the better quality craftsmanship and materials but most people just look at the over all price.
I would love a 34' GN triple axle built with payload in mind like they do there big trailers.
Dualie
Nor Cal
I had a couple of triple axles NEVER AGAIN. dual tandems only. T-1 steel and Murray quality would dominate.
The only thing i have found close is brute trailers out of Kentucky or Tennessee (i forget).
Newman
AZ
Why tandem duals over triple singles? I was wanting single so I could have the deck in between the fenders so its lower to the ground.
mitch504
Andrews SC
First, I'm just curious, what do you want to haul that is 6' wide and over 14,000 lbs or so?
Now, the forum probably won't give me enough space to list all the advantages of a dual tandem, so I'll just hit the high spots. :D
You have 8 tires hauling the load, not 6.
If you have a flat, the tire beside it will let you limp a ways. W/ a single, it usually completely destroys the tire, and often the rim, before you can stop.
Three axles make the trailer much more resistant to turning, so much so that if you don't have enough weight on the drive axle, in a slick spot the truck will turn, but the trailer will go straight.
Sharp turns put much more stress on the trailer, since 3 axles don't pivot like 2, but instead you have to drag one sideways.
Tire wear is usually much worse on a 3 axle.
Newman
AZ
Financially I'm not in the market for a new trailer right now. I currently have a 20' equipment trailer rated for 14K. I'm normally not near max weight but every once in a while I am. I haul a lot of 3/4 and 1 ton trucks. Going deck over puts the trailer to high to get cars or 2wd trucks on. My current trailer works great but I want something longer so I can haul 2 smaller vehicles(I have a early bronco and my brother has a CJ3A) and I don't really want to have 2 trailers.
Newman
AZ
The more I think about it the better tandem duals sounds. I always end up helping my friends move and I do a lot of city driving with tight turns so I would be wearing out tired like crazy. I wonder how hard it would be to have a air ride setup so I could dump the bags and lower the trailer if I had to haul something low to the ground..
OmniEquipped
Arkansas
Business Owner
