Bucket teeth
dsgsr
Monroe,Maine
Anything I can make $$ at.
How to keep them on? I know that I should weld them on. I will when good weather comes around (I live in Maine)I usually weld them on at the beginning of the season. Right now the hoe is a half mile in the woods. Unsure which way to put the holding pins in. Does the tit go up or down. The pins are metal with rubber in between and tits on one side of the pins and smooth on the others side. If I can get a pic. up you can see the type of tooth.20181214_141635.jpg Sorry, Not a very good pic/situation.
Thank you,
DaveG
dsgsr
Monroe,Maine
Thanks Canadian digger, That's what I thought. New ones are not holding well in the cold. I think the rubber in between gets hard.
DaveG
catman13
oregon usa
put bolts through them for now, or if you are not digging in dirt or rock leave them off
  • Like
Reactions: DB2
Leaving them off would wear out the adaptors. Bolts will work but use grade 5 or less. Grade 8 will snap while grade 5 will bend but stay in place.
digger242j
Southwestern PA
Self employed excavator
I haven't had to buy any for quite a while, but if I recall correctly, the dealer had some with the tits on both sides, designed to hold the teeth on to shanks that were somewhat worn out.
dsgsr
Monroe,Maine
Thanks for the info. folks. I broke down and walked the machine out and welded them back on. Please don't make fun, I'm not a very good welder:)
DaveG
willie59
Knoxville TN
Service Manager
I've seem H&L squeeze pin teeth fall off of new buckets with very little hours, then others stay on forever. But I'd still take H&L over Cat side pin teeth. Grrrrr
Shimmy1
North Dakota
Could you just have welded patches over the pin ends to keep the pins in, or do the pins break? If you're breaking pins, you need to rebuild the shanks, or replace them. I've rebuilt quite a few shanks. Not hard, just time consuming. Weld the shank up, grind it down, tap the tooth on. Pound it back off, little more grinding where you have interference, lather, rinse, and repeat. :cool:
dsgsr
Monroe,Maine
Not me. I could never be a Doctor, I have NO patients:)
