hellspcangel911
Hi All,
Im looking at buying this tb60 lift for completing some projects around my house, including building a barn. Its in pretty good shape overall, has the cummins motor with about 4500 hours on it and the 8ft basket.
everything works on it as it should except you cannot lower and raise the boom from the basket, so basically it takes two people to use it.
I'm being told by the seller they had someone look at it and the Digital Multiplex Receiver, part 601225, $2200 should fix it.
I am seeing mixed reviews on these lifts and prices all over the place. I like that its got the cumins and the rest of the lift looks good.
How likely is it that the receiver board is bad and would fix the issue? is there an underlining issue that would generally cause the board to go bad in the first place?
Are there cheaper alternatives, paying $2200 on top of the $7000 for the machine.... I found a post where the user had theirs fixed for $700 by http://www.providenceindustrial.com/support.php
Lastly, Is this a part that i could install myself (mechanic) or does it require the Optimizer or other specialty tools to install.
Thanks!
Thanks!
