03Z makes it a pretty standard turbocharged 250HP industrial/automotive application engine. The 03Z was never fitted to any item of Cat equipment.
Filters may be different between engines, depending on the brand of equipment it came out of.
One of the best articles I've seen written about these engines is by Roy Berndt, an engine reconditioning guru. The article came from a copy of Engine Rebuilder magazine.
Roy runs through the entire history of the 3208, from it's inception in 1967 in medium duty Ford trucks as the 1100 series, and goes into great detail explaining all the design differences over the years, and what you need to look for, if you want to start swapping components and engines around.
Scribd is the world's largest social reading and publishing site.
www.scribd.com
