Ivan Adiego
Hi, I'm a new member on the forum. I've been reading some of the related threads, searched online and downloaded some manuals but still not really sure what is going on. I bought a used 2012 TEREX 760b backhoe with 2300 hours a couple of months ago, It came with a synchro shuttle transmission (manual shifter, 4 forward and 4 reverse). After a long journey to my little ranch in the middle of nowhere I started testing the machine. First, I noticed some sort of metallic slipping noise that gets louder as you rev up the engine, this occurs in neutral and all forward and reverse gears regardless if the clutch is engaged or not. And second, its hard to shift into gear or even between gears, sometimes really hard to the point that I'm worried that I might beak something if I don't wobble the shift lever a bit to persuade it to go into gear. At first I thought it might be a worn clutch but the sound does not change at all when it's in or out of gear or if I'm driving or not, so this might not be the case (I'm guessing). I was thinking that it could be something related to the gear synchronizer assembly but I'm not sure. I don't have internet access where the machine is sitting at right now, so I recorded a video that picks up the noise that it makes when I rev it up. any advise on what might be causing this will be really appreciated!
