Bobcat Crazy
Hi All!
I have been able to play with Sweetheart a little since I finished building the engine. (sorry I don't know how to put the link to that thread here, I wish I did). I had the time to take down an old tree that I had been wanting to remove for a while now. When I did I found that one of the track adjusters needing rebuilding and the clam function would not hold pressure very good. The clam cylinders had just been rebuilt right before the engine went out so I thought I would start rebuilding the spool valve.
Also I found a lot of O-ring pieces lodged in the screen filter when I cleaned it so that is another reason I thought this was a good place to start.
I found it is a little more complicated (and a lot heavier) than my Bobcat skid steer valve but it has not been that bad now that I have a good manual.
I have disassembled the valves almost entirely, I still have to pull down the intake/outlet section. I have not found much missing O-ring material as I thought I would (just the really small O-ring on the secondary shuttle valve on 2 different spool sections). There was a piece of tag tie wire on the valve so I assume it has been rebuilt before at some point. But it was a long time ago. Though I found very little missing O-ring material, all of them are very hard so I am sure they are not sealing good.
I am off of work the rest of the week so i hope I can finish this project and get Sweetheart ready to take something else down before Monday when it is back to the "Salt Mine" for me!
The only thing that concerns me is the adjustment of the valves. The manual says measure the distance from the top of the body to the top of the adjusting screw. I don't have any issues with that but I just wonder if the last person that played with this valve knew what he was doing and if he adjusted it correctly.
Some of the lock nuts on the adjusting screws are only caught by a couple of threads and don't come all the way through the lock nut. So this makes me think they were not adjusted correctly when I started on it.
I called the local CASE dealer today to see if the had a way to bench test the valve assembly and set the adjustments on it before it was reinstalled. They were as nice as they could be (which surprised me since I am not a big money spender with them) but they actually had a 1155 in the shop and said they did not see anyway that could be done.
So if you guys have any thing that you have learned about setting these from your years of experience feel free to jump in and share with a rookie!
Thanks ALL!
B-Crazy
Thanks ALL!
B-Crazy
