I have a 95 1845c with originally weak drive motors on one side. The guy I bought it from had a machine that had bad drive motors and he swapped the motors fixing his and now the machine I have is weak. Sold it because it had been in a fire and needed alot hoses and stuff etc. So with that in mind the symptoms are strong right side motor. Weak left side. The linkage looks to be fine for both sides but my spool valves are leaking. I have replaced both drive motors and the symptoms improves albeit it is still noticeably weaker on the right side, when i replaced the motors no debris was noticed in oil, I kept a clean work enviroment and drained the tank and replaced fluid and filter. The machine is useable if you throttle it up. I know everyone screams tandem pump is bad, my question is, are they any other issues from the pump like the spool valve that can affect pressure. Ive read there is a screen that can get plugged but cant find any diagrams. The next step for me is to switch hoses to the other side and see if it follows. Any advice?
