muddog1975
I have ordered a paper service manualfor this machine, but it will not be in before I need it. Would anyone happen to know the test port locations for checking pressures. I belive this machine has a worn pump, but I need to verify it. Gear pump seems to be OK, lift arms are operating ok. Drive motors are not moving at low rpms. And at high rpms left track spins good and strong until I engage right side drive motor, then the left side drive motor slows and sounds like it grinding, then it stops. Like I said it seems like the pump is not putting I ut enough pressure to run both drive motors. Thanks in advance for any help.
