Friendof580B
Hello everyone,
I have one of my 580B Boom cylinders removed and disassembled for seal replacement.
It had been sitting idle for quite a while with boom in transport position and found that the outer gland seal rubber was completely deteriorated. The gland and rod came out of the tube without too much difficulty using a spanner wrench and long lever. I found it had been beat up quite a bit from previous owners..
I was able to finally get the gland off the rod using some light penetrating oil and tapping with 4x4 wood blocks. The gland had some internal light rust and crud, evidently from the rain and dust getting in from the bad end seal.
Question: Is there any need to replace this gland or just cleanup and new seals & internal bushing are all that is needed. (please see pics)
Also my parts book shows there were 2 or 3 part number variations of this boom gland over the years, and mine appears to be one of the older style glands and 2 piece piston.
Is there a preference/need to convert to the newer style gland or piston or just keep this style? (*Does newer gland design have better seal life, etc..)
piston if
Thanks in Advance!
piston if
Thanks in Advance!
