6ft5teddybear
Hello all,
I have an 89' Case 580K 2wheel drive 4 cyl Diesel backhoe. I use it on a farm for general purpose. Recently I noticed while pulling trees that there was fine mist hydraulic fluid coming from under the chassis. It only happens when the Hydraulics are pushed to the bypass limit. It appears to be coming from the bellhousing between the torque converter and the shuttle transmission. It only discharges when the hydraulics are up against the bypass pressure valve. Would this be an issue with the seal for the charge pump? The tractor still drives and forward and reverse. All Hydraulics appear to be working properly.
