syndy
Last spring I went up to NC and removed my right brake disk and the actuating plate assembly. Oil had leaked and it was like that from the previous owner, (a long time). I bought all the parts back to FL and tried de-greasing the disk using brake cleaner. The disk were in good shape as far as thickness and they seemed to clean up well, used about six cans of brake cleaner on them.
I disassembled the balls which measured good with a mic and the sockets were clean and not worn. I scuffed the metal surfaces with emery and reassembled the actuator and bench tested the movement as you pull on the clevis rod. Everything seemed to be working and in good shape
A couple of weeks ago I reinstalled a new seal and all the brake parts. I adjusted the brake rod nut until the pedal feel was about the same as the left brake. I checked to see that the rod was pulling up as the pedal was depressed indicating that the pads had pressure on them, all worked fine. (Also made sure no more oil was leaking through the new seal). So with all the parts supper clean and back together I have still no right brake.
Thinking that de-greasing the plates was not working, I raised the right wheel and let it spin for a few minutes at about 1500rpm. No sign of any brake, not even a hint. Other than that brake everything on the tractor works perfect. Any ideas except replacing the disk with new ones?
