CottageAndy
Hey everyone. I am new to the forum, but have been lurking for quite some time. Excellent resource. It has helped me out many times already. Now I have a problem where I am seeing conflicting information. I had to change the serpentine belt on my 580SL and (after MUCH pain getting the coupler to slide on the spline!) noticed a slow fuel leak at the throttle linkage for the injection pump. I used this forum to find the details on removing the pump and had a local diesel shop put a seal kit in the cover side of the pump. When I got it back i reinstalled and it fired up, but was leaking like a sieve at the cover plate seam. I removed again and took it back to the shop and they fixed it, (hopefully..they said they tried to use a cheap chinese seal for the cover gasket and they sometimes leak...go figure) I reinstalled it and now it won't fire. I read here that it could be 180 out of time if it happened to be at TDC on an exhaust stroke, but every video I've seen on the removal of the pump only show people barring the motor over til the pin slides in and then they lock the pump and that's it. Are they all just getting lucky? I just wanted to ask the question before I take it off again to spin the motor as it's possible that I have another issue, like a weak lift pump. Sorry for the long post. Engine is the 4T-390 and the p.n for the pump is 0460424081 (I think...it's pretty worn) TIA
