I purchased this CASE 850C about three months ago and never had to select the range from Hi to Low. I tried selecting it while the engine was running. When making the selection from HI to LO coming out of HI was no problem .. it was going into LO was like wanting to grind gears.. I got off of it quick ... So I tried bring it back into HI position and it too wanted to grind...
Decided to turn off the engine.... Then made a selection to LO... the shift would not lock into LO position... I then went back in to HI position ... once I did I started the engine and checked the unit for forward and reverse movement ... all was ok ...
What puzzles me is why it does not synchronize into HI or LO range with the engine running?
