Case 850D torque converter removal
Brent Zeirott
Johnstown Ohio
Retired
I took my belly pans off to clean. Noticed fluid was dripping from the bell housing hole. Pretty sure it’s leaking from the torque converter area. Engine oil level is fine. 2 quarts low on transmission. How does one remove the torque converter housing? I’m assuming there is a seal gone bad. The dozer is up on several boards for clearance. I just wonder how the removal process is?
Thanks!
