Hi All; About a week ago i purchased a 2002 Case 95XT. Since i bought it, it would randomly/intermitantly shut down and the display would start to flicker. When this happened it drops our the fuel shutoff solenoid and stalls the machine. It got progresively worse in the week i've owned the machine and now it will fault/flash/flicker a few seconds after ignition power is switched on.
I've spent some hours troubleshooting so far have done the following;
I've attached two short video clips showing the fault.
The machine will start but immiediatly stall out once the display starts to flicker. 2002 Case 95XT would randomly/intermitantly shut down and the display would start to flicker. This drops our the fuel shutoff solenoid and stalls the machine. It got worse in the week i've owned the machine and now it will fault/flash/flicker a few seconds after ignition power is shut down.
- Confirmed battery has a full charge and installed float charger
- Cleaned checked and lubricated most electrical connections
- Checked and cleaned main machine ground connections from battery through disconnect to engine.
- Replaced all 5 relays
- Visually inspected wiring harness where it can be seen. Haven't found any broken or damaged wires.
- Checked alternator circut / tested resistor/ disconnected alternator (no change)
- Checked connectioned to left and right instrument panel (fault still occurs with Left Instrument panel disconnected)
- Had some intermitant issues with ignition switch, replaced switch (no change)
