chuckiecage
Been trying to find a reasonably priced alternative for Case TCH fluid, traveler premium at Tractor Supply claims to meet TCH specs but cant find any data to back it up.
In the PDF below that lists Case specs on fluid this now confuses me even more, Case recommends
LOW TEMPERATURE HY-TRAN ULTRA (MS1209) as a TCH alternative (second fluid down on the page)
but if you look at the specs for CASE TCH FLUID (MS1210) (fifth fluid down)
it more matches the first fluid CASE IH HY-TRAN ULTRA (MS1209) specs (first on the page) but is not recommended either on this sheet or by the local dealer as a replacement and conveniently the low temp stuff is more $$$ too, can anyone with more smarts than me weigh in on this??
also from my extensive research I seem to have found about a 50/50 success rate vs horror stories from people that switched to HY-TRAN ULTRA (MS1209) in TCH required machines
