Got the injector lines bled out today and the old girl fired up. Takes quite a bit of cranking before it starts and runs. I hate to have to hit it with ether, but I also hate to grind the starter forever. Still sounds rough untill you put a load on it, then it smooths out a bit, but after idling for a while it starts running rough again. It also quits smoking, but as it idles I see it start to smoke again. Any thoughts as to what might be the issue? STill running on the trolling motor tank, but I don't think the rate of fuel supply is an issue. New air filters now, too, so I can't blame it on an intake restriction.
I still see some seepage from #2, I think, cylinder injector connection, even after loosening and tightening it several times.
I ran it for about 10 minutes, and it didn't seem to get quite as hot today. I still need to get a thermometer and measure temps. Should have thermostat tomorrow, so I'll get that in and an official non leaking gasket. I think the material I bought isn't suitable for water connections, as I made a gasket for the thermostat housing on my truck and it seems to be leaking now, as well.
One other thing that puzzles me, there are wires over the cylinder head that I assume are for glow plugs. The crank switch moves outboard and works a solenoid, that I assume would be for glow. But I see no provision in the cylinder head for glow plugs... Might be hard to see in the included pic, but there's a conduit that carries the wires over the valve cover.
