Staggerlee
I bought a 2000 CAT 246 that needed to be repaired. Broken rod, hole in the block, basically total failure.
It has the CAT (Perkins) 3034 4 cylinder turbocharged diesel engine.
It requires a block, at least one rod and a crank or crank repair that involves welding and regrinding.
Sourcing parts has proved to be a major problem. CAT wants 12k for a long block. There are several on eBay at that same price, Drews salvage has a rebuildable core for $6,500. All off those are out of the question, I'll cut my losses and part the machine out before spending that much.
One option I am trying to explore is, using a naturally aspirated Perkins 704.30 from a Daewoo 1760XL skid steer.
Perkins number for the CAT engine is 704.26 family is "UB"
Perkins number for the Daewoo is 704.30 family is "UA"
CAT block casting number is 3711H09A/4 HP rating is 74? I believe?
Daewoo block casting number is 3711H09A/1 HP rating is 63? I believe?
As you can see the only difference in the casting numbers is the last digit.
Both motors are 2.9l, visually from an external comparison, the blocks seem to be identical with two exceptions.;
1. The CAT 3034 has a threaded hole for the engine oil dipstick. the Daewoo has a pressed in dipstick tube, located a bit higher on the block. The emboss is still there on the Daewoo block, just not drilled and tapped.
2. The oil drain from the turbo back to the block is the same situation. The CAT 3034 has a drilled and tapped hole for the turbo oil drain. The Daewoo only has the emboss.
I can purchase the Daewoo short block including rotating assembly for under 1k.
My thinking is to recondition the Daewoo short block, then use the cam, injection pump, cylinder head and turbo from the CAT. I have no way of knowing if the turbocharged engine used more robust pistons, rods and crank, but hopefully the rebuild parts from the CAT kit (including pistons) would work in the Daewoo.
Am I crazy for considering this as an option for a personal use machine?
Looking for some constructive feedback, thank you.
https://es.ruttsmachine.com/assets/pdf/literature/es/Perkins-Engine-Number-Guide.pdf
