CotterFCattle
Hello all,
I have a cat 257b serial # SLK05001 I purchased a while back. I am having trouble with the aux hydraulics for a grapple, etc. This is a high flow machine so it has a thumb wheel. Here is what it is doing:
- Pull the thumb wheel down and hydraulics function correctly. With no tool on it labors trying to push oil.
- Release thumb wheel and machine keeps laboring.
- Push thumb wheel up and it quits.
-Pushing up does not make it push oil in other direction.
Please note that I DID try replacing the thumb wheel. I was positive that was the problem, and it was not. Luckily CAT let me return an $1150 handle....
I have tested the solenoids on the valve and they both show the same amount of resistance with a multimeter.
I have used a test light to verify that the connector to one solenoid is receiving power, but the other is not.
Therefore, I have an issue somewhere between the switch harness and the wire that connects to the solenoid. Where should I go next?
I saw that there is something in troubleshooting info from cat about what to do if the switch only works in one direction, but I have not been able to find it.
Thanks!
Thanks!
