aheeejd
I have a 257b, it has been sitting for about 6 months as I worked to save up for new drive motor. Replaced motor, filled hydraulic tank. Now I should have tested battery 1st,but I did not. I hooked up charger, 12v 30amp for half hour. Then I put charger to start mode, hopped in cab, pulled arm bar down. Turned key, & I had lights. Turned key to start position & nothing. Dash lights went out. I checked reset button above motor on left hand side. Nothing. Battery reads 12.8v.
Serial # is SLK06218
I'm not very handy with wires, drawings or a volt meter. I hope I didn't fry something. That drive motor was not cheap.
I checked key 10 amp fuse. And it was good. If anyone could please help that would be great.
