Cat 257b power at ignition but won't energize start relay
Andy 9000
Rimbey, Alberta, Canada
Hello, hoping I can get some advice. I have a Cat 257b tracked skid steer, dash lights come on with ignition in run position but when I turn it to start position it's not energizing the start relay in the engine compartment. I have disassembled the instrument cluster to test the ignition, it is testing good. I've tested the ignition relay and it is also good, just to verify I replaced it with a spare but made no difference. I've tested and verified the seat switch is working, I've verified that the lap bar switch is working (I'm not really sure how to test a 3 wire hall effect sensor, but when it is lifted the dash light for the lap bar illuminates and then goes out when it's lowered so I have to think it's working). I've checked all the fuses, they are good. It's nothing to do with the battery, if I use a jumper wire to energize the output wire of the start relay and have someone in the cab it starts just fine and runs as it should. I tried to trace the wiring but it has been a struggle to follow them through the machine. Would be terrific is anyone has had a similar problem or has a wiring diagram for this machine to share (ser: CAT0257BASLK08627). Thank-you
Andy 9000
With the help of the schematic I was able to narrow it down to a section of the harness, where I found a hose had rubbed through the loom and into the wire bundle. Thank-you for your replies, really appreciate the assist with this repair!
