CAT 257B #SLK03341 interlock problem
Corn Cob
Elkins, West Viriginia
machine was running fine when i shut it down restarted 30 minutes later safety bar and park brake light flashing .i returned 1 hour later and reset blue button on breaker i started machine it ran fine. i shut machine down for the night restarted next day everything worked fine all day. parked machine 6 hours later. went back
2 hours later machine starts fine but safety bar and park brake light flashing. checked reset breaker its good. i don't think breaker was tripped the first time. Seat switch checks good. safety bar switch must be good if it only starts when down.
I think you may find all the answer in the thread linked below. All the troubleshooting documents plus the electrical schematic will also work for your Serial Number.
One thing you need to be very careful about are the errors that were discovered in the text of the Cat troubleshooting procedure for the fault. Read the thread carefully starting from Post #55 on Page 3 where it was discussed.
