Frank Nesbitt
I recently acquired a early (YYZ05843) CAT 259B3 skid steer. When cold, the machine cranks and runs fine. Lots of power and no skipping, smoke...nothing out of the ordinary. After running just 5 minutes or so if the engine is cut off it will crank back up if tried in 10 seconds or so. Wait any longer and forget it. Acts and sounds like no fuel. I have checked the electric primer pump and verified fuel is getting to the injector pump. I have opened an injector connector and get almost nothing in the way of fuel except a spit or two. I would assume (yes I know what this means) the high pressure pump has issues. Since I have never torn into an injector pump does anyone have any suggestions? Is there something else I could check before spending $ on pump? Thanks for all relevant suggestions
