2204-3 Auxiliary Lever #1 Position Sensor Voltage Above Normal
2475-3 Right joystick Forward/Reverse position sensor voltage above normal
2477-3 Right Joystick left/right position sensor voltage above normal
I am unable to move the bucket at all and I assume that has to do with the "right joystick" errors, but what does the Auxilary lever one mean and what do I do for all of these errors? Thank you.
If helpful, I can give the serial number to someone that thinks they can help. Thank you.
