Traivs
We have a CAT267 Skid Steer. The issues started a few weeks ago. It was being used and after about an hour is shut off, checked all fluids and duel. Everything looked good. It started back up and ran for 30 more minutes, then died. Let it sit for a day and came back and it fired up fine and ran for awhile (2 hours) and died again. It wouldn't start after that. It starts for maybe a second and dies out. Tried bleeding the fuel system, replaced filters. flow seems normal. It has a fuel shut off solenoid and I suspect its bad and causing the problem. I'm not entirely sure though. Any information would be greatly appreciated. The only info center it has is just a display in the upper left corner of the cab that has warning lights. No lights are illuminated when it stalls. Not sure if it stores coded or how to pull them. stumped.
