torey driver
I have a Cat 279C2 serial number AT0279CTKWB00583R that has a drive problem. If you drive forward slowly it will move forward. If you stroke the joystick more it locks up the left track. If you slowly go in reverse it will ease backward but will lock up the right motor with more stroke of the joystick. It will eventually make forward go reverse and reverse go forward with the joystick. It has no codes active. I had a mechanic hook up to it and the numbers for the joysticks looked good. He ran a calibration test and it said left speed sensor code. Replaced left speed sensor and tried driving and same problem. Any help would be greatly appreciated. Trying to figure out if this is a hydraulic or electrical problem but seem to be leaning to electric.
