I am trying to understand the fuel system. Can someone please explain where I am wrong, I have a rough drawn photo for reference.
Fuel goes from main tank to small particle filter, through priming pump and to the water separator/filter.
From this point I'm unsure of flow.
There are 2 lines that go from there to a secondary tank, what is the flow here, one goes to the bottom, one tees off the top to the fuel injector pump? There is also another line from the secondary tank to fuel injector pump? What is the flow of this?
Then there is another line that goes from the back of the secondary tank to main tank, is this an overflow back to main tank?
It's not easy to get a photo of what I am calling the fuel injector pump, but this is the best I have. Is there an imv valve that's there that I would have to check, is there a good photo of this so I could know what I'm looking at.
