Dr. W
The machine is a solid machine with alot of improvements.
Very easy to service!
The engine program checked and reloaded and the RPMs (full power) found to be 70 RPM low.
The rear idler was replaced by CAT to insure that there would be no track problems. The ride is smooth and quiet. Track adjustment is now a breeze!
The fuel burns are about the same as the 287 using standard flow.
The Cab has great vis and the seal is good. (The dirt stays out!)
The E/H controls I am used to and they have a bit of a lag however, no hill for a climber! This will give CAT something to work on..
Moved some big trees with the grappel bucket and it handles at bit better than the 287 with heavy loads. (Well balance)
Runs high flow tools real well!
