CAT 289D3 BLOWING BOOM LEVEL FUSE, AFTER CHANGES NOW HAVE 2476-3 2477-3 2474-3 2475-3 458-3 41-4
joedirtyshirt
PA BERKS CO.
THIS IS KINDA TURNING INTO SNOWBALL/AVALANCH ,so after blowing fuse for boom sensor, it would blow after a bounce or two, swapped out sensor on boom with a know good one and fuse blew the same way, checked boom harness found suspect damage to cover so installed new harness, now have these codes 2476-3 2477-3 2474-3 2475-3 458-3 41-4 and park brake won't go off. any ideas, or what am I over looking with either issue, triple checked connectors that were plugged in correctly
joedirtyshirt
PA BERKS CO.
In mean while I overlaid old harness back in and problem is still present and looking not seeing anything that I may have knocked loose , still pulling what is left of my hair out
Would you like to start with a machine Serial Number.?
I see multiple models of 289D3. A S/N makes it far easier to look up information.
Out of that list the 41-4 is a very likely candidate because it relates to the 8v stabilised power supply to all the sensors.
The -3 Codes for 2474/75/76/77 all relate to joystick position sensors.
458-3 is the tilt cylinder rod end pressure ensor.
  • UENR3699-17 MID039 CID0041 FMI04.pdf
  • UENR3699-20 MID039 CID2474 FMI03.pdf
  • UENR3699-20 MID039 CID2475 FMI03.pdf
  • UENR3699-11 MID039 CID2476 FMI03.pdf
  • UENR3699-20 MID039 CID2477 FMI03.pdf
