ColdBlackWind
I did. If memory serves i went through the exercise to check any fuel bypassing.Could you possibly hook up ET to your machine and take a look.?
I. Et you do an event logging or live data display when cranking, you'll see a desired fuel pressure and then the actual fuel pressure. That's how you know if you're meeting what's expected.I’m working with ET also, the pressure is 4600 psi on mine when cranking
I have that data in a waveform if interested.The fuel pressure reading from the rail during cranking would be interesting to see.
All it needs is a screenshot from ET showing the Desired and Actual Injection Actuation Pressure values during cranking. That tells you everything you need to know. If the AIAP never reaches the DIAP there will be no smoke from the chimney.I have that data in a waveform if interested.
Nige,A DPF Regeneration Time Interval Reset must be performed when the 523602-0 High
Frequency of Regeneration code is active. Performing this reset will change this code from active to
logged. To do that requires ET.
I would say active. I was trying to see if it was safe to move to logged (reset) to see if it came back or not. Based on what I could see in ET, it hasn't tried to do a regen in a long time, since before this, get your head issues from what I could tell according to what the old owner told me, it's third-party info,, he said she said...,Question: Is the 523602-0 Code Active or Logged.?
If the latest software was in your machine ECM and display monitor, the 3000 hour "DPF requires cleaning" service reminder wouldn't be there. If you had the latest version of the Operation & Maintenance Manual, you'll see the DPF Cleaning has moved from the 3000hr section to the "As Required" section. This is because plenty of DPF's go more than 3000 hours. Plenty go less too, lots of factors involved.If the (dpf) in good condition (cleaned) does it really need to be removed and cleaned? (It also has the 3000 hours required cleaning notice on the display)
No. Not unless you've had the DPF cleaned. It screws up the regen logic that controls burns.2. In my case would you consider it safe to do the reset for the 523602-0 code I have?
What are you using to read codes? Did you buy the actual CAT software and dongle or go a different path? You can message me directly if you don't want to answer in an open forum.This summary data is from a 20-30 minute run.
DPF differential pressure: about 0.13–0.50 psi.
SIS DPF differential pressure regen trigger range: 0.9–1.5 psi.
DPF soot loading: about 39–42%.
DPF soot mass: 8 g.
DPF soot mass #1: 4 g.
DPF soot mass #2: 9 g.
DPF regen level: Regeneration Not Needed.
DPF regen status: Regeneration Not Active.
DPF regen progress: 0%.
Active regen inhibited: mostly Not Inhibited, with a brief Inhibited reading near the end.
DOC intake temp: up to about 420°F.
DPF intake temp: up to about 420°F.
DPF outlet temp: up to about 400–420°F
