Hi All,
I have a Cat 302.5 mini digger, All seems to be working fine apart from having no real downward pressure. If i extend the boom our a little, sit the bucket on the floor i'm unable to lift the digger but everything else seems fine, at least i haven't noticed any other issues. Dig's fine, moves around with no issues and the Boom works just as it shoudl although a little jerky but she is old and done just over 5000 hours
I've been told by a friend that it could be the hydraulic pressure is at fault and i may be able to make it slightly better ( without having to replace the pump ) by adjusting the pressure relief valve ?
No idea where that is or if it can be adjusted. Is anyone able to point me in the right direction please.
Just as a side note, if i lift the boom up and leave it there floating in mid air the arm doesn't drop at all, i tried it over night and in the morning it had only fallen half way down to the ground so i'm confident its not a seal in a ram or anything.
My serial number is 4ZW10731 / Product ID is CAT03025C4AZ07147
