Cat 303.5 leak from Hydraulic fluid filter cover
Kekoa512
Honolulu
Hydo flows out when it’s pressurized after I removed the cover and reinstalled. I took it off again, cleaned up the o-ring and mating surfaces, and reinstalled. Still leaking.
Hoping this is just an o-ring issue? It seemed like it may be a little loose, not a snug fit into the groove it’s supposed to sit in. Anything I’m missing before I replace o-ring?
Kekoa512
Honolulu
I’d call it a big weep. It didn’t do it before I took the cover off; only after I put it back on so im hoping it’s just an o-ring issue
Kekoa512
Honolulu
@Nige that's the bummer, I don't have a serial number. Sorry for the delay, I thought i had sourced the right o-ring but i was wrong. I know it's the o-ring/seal under the cover to the hydraulic suction strainer and I THINK my rig is an old 303.5D CR or just CR. Do you know the exact name of that cover I'm talking about? Hoping i might find the o-ring if I know what CAT calls that cover
Cat will simply call it a cover. The problem is that without looking the cover up by machine Serial Number getting the correct Part Number is somewhat of a lottery.
Did you buy a Cat Part Number.? If yes, what P/N did you buy.?
